Old 08-30-2015, 06:34 AM   #3
jsceash
jsceash's Avatar
Been running this combination for 3 years. As others noted.
1.Transfer your C,P,F to the new motor or renew they bolt right up. You'll also need Flywheel bolt for a manual.
2.Transfer the engine wiring harness from the manual motor.
3.There is a 4 way "T" and 3 way "T" cooling hose on the Tip motor use the 3 way hose and the "L" shaped hose from the Manual motor.
4.The vacuum line on the tip at the intake has a 4 way tee use the manual 3 way "T" from the manual motor.
I believe that is it.
