08-28-2015, 10:26 PM
#1
Originally Posted by jakeru
I have two links for you:
Boxster Hacks and Instructions
Porsche Boxster Shocks & Spring Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
I like the balljoint press tool from harbor freight, although it does need some grinding/clearancing to fit around the shaft of the thick porsche ball joints. Easy if you have any sort of grinder (bench grinder, angle grinder, die grinder).
3/4" Forged Ball Joint Separator
I found it helpful to loosen the lateral a-arm bolts where they connect to the frame, so the lateral arm can be pressed down without fighting against torque in the rubber joint. This will upset the alignment, though. I didn't find it necessary to remove or loosen either end of the trailing arms (where they connect to frame or to lateral arm).
I believe any Macpherson spring compressor should work. You will need to remove the strut before being ready to compress the springs, though.
Thanks for the info everyone!
2001 Boxster Guards Red
