Old 08-28-2015, 05:17 AM   #3
emore93
I had a similar problem.
The issue is the window regulators. There is a piece that wears/breaks and creates enough slack so that the window will not roll down far enough to clear the top.
To verify you can push the window down with your hands to the correct height (till you feel tension from the regulators).
Replacing the regulators is the permanent solution but there is a hack you can do that uses wire ties. I don't have a link but you should be able to find it if you do a search.
I tried it but it didn't work for me.
You can get new regulators from rockauto from around $120.00 each.
emore93 is offline   Reply With Quote
