Old 08-21-2015, 08:12 AM   #6
Chuck W.
Chuck W.'s Avatar
Originally Posted by alm001 View Post
Chuck,
You shouldn't have to have the CD reader connected for power. I actually took a pic of this when I was removing it, for some reason!
Thanks Andrew!
I am betting that the wiring harness is different when the factory installs the PCM. Plug A wire 7 is powered on the CDR radios and not on the PCM units. But, your photo shows me that there should be a work around for this.
I am betting if I can figure out which wire powers up the PCM head unit I can jump my wire 7 to it.
But then, I have read that others have plugged CDRs into their PCM wire harnesses and they work... ugh.
1995 Porsche C4 Cab
