Old 08-19-2015, 06:48 PM   #2
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by BoxsterSteve View Post
It looks like you barfed up an AC condenser. Could be a rock strike or just old age. Pull the bumper cover for a peek. If you had "0" system pressure to start with, there was already a good size leak present.
As for your oily substance, there is oil in with the refrigerant charge to lubricate the compressor. Betcha that's what you're seeing there.
+1 My bet is you need a new condenser, pull it apart and check. If you have the correct coolant it is pink not green. If it is the condenser you have not screwed up, your AC is just shot. Pull it apart and post pictures, we'll help you through it. No big.
2003 S manual
