Old 08-13-2015, 07:59 AM   #10
abranovi
This is an interesting comment - I had the same experience back in 2012 when I was test driving Boxsters. I only drove a handful, but by far the best shifting of them was a 99 2.5 Boxster 5 speed - it shifted like butter, every gear change was silky smooth. The 2001 2.7 5 speed I drove was different, not nearly as smooth, still good but in comparison not as smooth. It had a lot more power than the 2.5. The 2000S that I ended up getting had the worst shifting of them all (still not bad, but relatively speaking) but that resolved with a gear oil change and upgrading to a 9x7 shifter. When I took the old shifter out it looked like a dog had chewed some of the rubber pieces which I believe were binding up.
Okay- so I guess it would need a rebuild. What did that overhaul run you, if I might ask?
abranovi is offline   Reply With Quote
