Old 08-08-2015, 08:42 AM   #3
rick3000
There Is No Substitute.
rick3000's Avatar
When you say you can only move the AC controls a quarter of an inch, do you mean you cannot even pull them out to disconnect the wiring?
If that is the case, I would remove the triangular carpet panels under the center console (they pop off), and try to reach up and loosen the wires, or feel for any catches/snags. It is possible to reach all the way up from the bottom, but you might want to wear gloves as there are some sharp edges.
Good luck!
