Old 08-08-2015, 08:21 AM   #1
Mr.JonathanLanda
Originally Posted by Jamesp View Post
I'm putting in a double DIN into a 2003 S and intended to move the AC controls down as I've seen on other threads. The wiring harness is very tight and allows me to move the AC control panel about a quarter inch max. Anyone have advice on moving the AC controls? I'm thinking about just putting the double DIN in the lower console, but that's a compromise.
Nope, you have to remove the AC white subframe and try to extend the cables. It is very much worth the hassle.
Tips:
AC all the way at bottom near shifter.
You will never hit it because it's at the base of the lever.
Then on top of the AC, where the gear lever hand rest is, there is a little pocket thing, perfect place to put in cell phone.
The double din was a pain because they have to take apart all of it I order to properly manage the cables.
Took 4-6 hours
Mr.JonathanLanda is offline   Reply With Quote
