Old 08-06-2015, 03:26 PM   #10
Qmulus
inveniam viam aut faciam
The cars mileage is logged in the ECU and the cluster. In order to get the new cluster mileage to match your actual mileage, you will need to copy and paste the files from your cluster onto the new cluster using an EEPROM reader.
That works in the early clusters, but on the '01 and up the EEPROMs are encrypted, so you can't just read the EEPROM, modify it and rewrite it. If you are lucky and get the exact same part number and firmware revisions you _might_ be able to swap files, but in my experience that doesn't work.
It can still be done obviously, but you need more equipment and software to do it.
YMMV.
Steve
Qmulus is offline   Reply With Quote
