Old 08-06-2015, 10:50 AM   #1
hancock1701
Brake Rotor Resurfacing
I've had this happened to me twice, so I was just wondering what other people do. When I replaced the pads, I measured the rotor, and thickness was still above the minimum. However, when I took it to the store (Pepboys) to get resurfaced, they wouldn't do it because it wasn't "thick enough".
I didn't have time to go around to see which shop would do it, but what would you do if nobody would turn your rotor even though it's still within spec? Is there a limit where it's thick enough to use, but no enough to be resurfaced? Mine didn't have any abnormal or uneven wear, just wanted it to be perfectly flat.
hancock1701 is offline   Reply With Quote
