Old 08-03-2015, 06:58 PM   #11
Mike689
Originally Posted by Fintro11 View Post
how is your air filter / tire pressure?
The tire pressure is fine I checked it 2 days ago. I should probably change the filters though.
Yes; Listen to your engine and feel the pressure you are using on the throttle. The engine will communicate back to where it wants to run. You will have much better results. I have driven my 2.5 into So CAL down the 215 rarely using 5th gear and have gotten 32 calculated freeway. I believe you are so low in RPM the knock sensor is retarding the ignition timing. Try keeping at 3.2k +. I don't think your plugs are an issue since you just bought car so had to pass CA smog. Of course new plugs are always good.
Damn I'm such a newbie lol. I've driven a manual car before but it wasn't a sports car and this my first car with manual. So I've been lugging my engine for like 3 weeks I hope I didn't screw things up too bad.
Mike689 is offline   Reply With Quote
