Old 08-03-2015, 05:44 PM   #1
BYprodriver
BYprodriver's Avatar
If your check engine light is off & in working order, (insure it is on when you 1st turn on the ignition switch) it may be injector or sparkplug related. Put injector cleaner in gas tank & then fill tank with Chevron premium. This is designed to clean fuel system & combustion chamber in cylinder heads. The debris that is cleaned can get past piston rings into the oil sump so you should change oil soon after that tank of gas is gone. Replacing the sparkplugs should improve efficiency also. Search this forum to decide which oil to use.
