Thread: Top Alignment
Old 07-31-2015, 07:01 AM   #1
jeeper31
jeeper31's Avatar
Originally Posted by Thumper View Post
You'll need some help to do this correctly. Loosen the three attachment bolts on each side of the top and pull up and back on the top. While you're pulling up and back on the top, have your helper retighten the mounting bolts. This should allow the top to fall into place like it did originally. I had to do this when I swapped my '01 top for a '04 top. Took a couple of tries before everything was perfect. Hope this helps.
Thanks for the reply. Sounds easy enough. Where are the attachment bolts? I have to loosen the left and right side? Will this change how tight it closes? What are the chances I am going to make it worse? (I have a tendency to do that. lol)
jeeper31 is offline   Reply With Quote
