Old 07-28-2015, 10:24 AM   #21
EJ-Fresno
EJ-Fresno's Avatar
Originally Posted by Chuck W. View Post
According to Pelican; Replacement Boxster transmission mounts include the triangle-shaped bracket. At about $250 each, they're pretty expensive. While performing the installation of the Porsche 996 engine into the Boxster, I discovered that the engine mounts from the 993 are functionally equivalent, and are sold without the triangle bracket for about one-half the cost of the Boxster mounts. You will have to carefully remove your old triangle bracket off of your old mount and install it on the new one if you decide to go this route. The stock 993 transmission mount part number is 993-375-049-05.
I would do this... buy from Sunset Porsche (Genuine OEM Porsche Parts | ************************************************************************.com) and have them ship the parts to you.
Motor Mount $138.62 987.375.023.05
993 Transmission Mounts - Two at $163.89 = $327.78 993-375-049-09
Total $466.40 plus shipping.
Sunset sells the Boxster transmission mount with the bracket for $295.02 each. If you bought two of those and the motor mount from Sunset your at $728.66 plus shipping.
Thanks Chuck, that's what I was referring to.
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
