Thread: Oil Starvation
Old 07-28-2015, 08:50 AM   #21
Fyeganeh
Fyeganeh's Avatar
All these items treat symptoms, they do nothing for the underlying conditions that are the root of the true problem.
I assume you mean the root problem is many oils losing viscosity at high temps whereas Driven DT40 and the xp9 racing oil not doing so. I believe you don't think it has as much to do with lateral g-forces. (I have switched to DT40).
But my question is in a 15 year old car does the piston actually wear out/break and need replacing so as to prevent damage? Is it designed to last 15-20-30+ years?
Thanks,
Fred
Fyeganeh is offline   Reply With Quote
