Thread: 24 bent valves
Old 07-26-2015, 08:08 AM   #10
flaps10
flaps10's Avatar
If it was timed correctly before, and is timed correctly now, and the valve marks are fresh then my theory is that you had a chunk of something take a ride around the primary chain that goes from the crank to the intermediate shaft.
It has happened before. In one case it was a rod bolt that came out. Could be a chunk of plastic chain guide too.
Either way, plan on that tear down
flaps10 is offline   Reply With Quote
