Old 07-25-2015, 01:05 PM   #2
Dremzy
nope the transmission doesn't make any noise. The motor only works when i connect a 12v battery.
The roof head mechanism is a bit touchy could that be it? I can play with it and get the windows to drop, but does it have any function? Hence is me playing with it and getting the window to drop it's only function as if it is, replacing it won't solve the problem.
I have just noticed the following above?? When looking behind the passenger seat there is one cable that plugs into a connector. Next to it, there is another connector with 1 metal pin. Nothing is connected into it, do you know what this could be?? Maybe something is missing and the mechanic has removed it.
Dremzy is offline   Reply With Quote
