Thread: 24 bent valves
Old 07-25-2015, 09:34 AM   #7
thstone
Sorry but this post doesn't make sense.
If the only thing wrong with the engine is that all of the valves are bent, then the timing had to be off on both banks at some point in time. And if the timing was off, then you have a serious problem and you need to find the root cause before putting it all back together.
I'd completely tear down the engine. I am sure that you'll find your root cause...
