Hi B Feller.
Ok so the new relay is in which is bringing the windows down, does it also control the motor?
When I press the button to take the roof down i hear a very quick electric sound, but no motor sound form the rear of the car. Is there any way to test this motor?
The mechanic told me it was the relay that was at fault and not the motor.
With the fact that the new relay is in, should the motor be working even if all the push rods/linkages are removed? I'm guessing there are no sensors to detect this, so the motor SHOULD be working??
Is there anything that could be preventing the motor from working, sensor wise?
Just to confirm, the parking brake light is on.
I do however have a problem with the transmission, it flashes between 4 and P. could this be preventing the roof motor from starting?
