Old 07-18-2015, 02:53 PM   #5
epapp
epapp's Avatar
If it caused condensation on the fender then it was steam and not smoke. I would check the water pump/main coolant tube connections.
Those being fine, more suspect would be the expansion tank connections on the inside of the engine bay. You could have a split that only leaks when the system is under pressure.
epapp is offline   Reply With Quote
