Old 07-12-2015, 09:22 AM   #13
navair
Originally Posted by jsceash View Post
The Urethane bushing with a steel sleeve are a compromise they allow a little compression and extension. For street use softening the ride, which maybe isn't bad. For track use or autocross that little bit of flex affects toe and caster. This is why serious track driver switch to all mono-balls and solid, and billet bushing inserts. Its like running V and H rated tires instead of Y and Z recommended tires. They drive ok to a point but as you push them the flex isn't there and you experience more push and rear end slip. Continued use at higher speed can break down the side walls or cause tread separation's.
The final analogy is do you want to drive a sports car with the feel of a sports car or a sports car with the feel of a sedan.
Agreed. I was cheap when I bought them, and I wasn't tracking it then...
navair is offline   Reply With Quote
