Old 07-12-2015, 06:52 AM   #11
navair
If you are talking about the long arms that bolt right behind the firewall & connect to the rear lower control arms, I don't see where they can use poly mounts. Problem with polyurethane is it is prone to binding, the last thing you want in a well designed suspension. You want the best bearing you can get there so get TRW made arms. I would be very wary of buying anything from Vertex. The floating captive nut that secures that bearing is easily damaged so be careful when loosening & torquing it!
I respect Byprodriver's knowledge, but I have had the vertex poly arms on my 02 S for years, and autocross the **************** out of it. They work fine. But, I will put TRW arms in at some point...
navair is offline   Reply With Quote
