Old 07-09-2015, 12:15 PM   #14
soxfan1966
Originally Posted by ilikeching View Post
Hi,
Just want to share this simple DIY 3rd brake light flasher, delay version.
I've seen this on F1 race cars, kinda cool and it's proven more visibility when it flashes, and it's great safety issue.
I went for delay version because in rush hour traffic brake light will act normally on solid(slow drive, hit&brake all the time)
and will not irritating other drivers during rush hour.
The brake flashes 6 times about 2 sec and then turn solid, touching your brakes again within 8 seconds will cause
your third brake light to turn on normally without flashing.
!! With the module, you need a simple resistor to work properly on Boxster !!
no error codes. simple install.
3rd brake light strobe, delay version Porsche Boxster 986 - YouTube
I have tried both from Kahtec and 3rdbrakeflasher.com, 3rdbrakeflasher module is programable. i haven't found other brand with delay version, both are great.
you need resistor to work properly both og them.
Are there any instructions on what to use for a resistor and how to wire that in with the module ?
soxfan1966 is offline   Reply With Quote
