Old 07-05-2015, 07:06 PM   #26
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by Montesinnos View Post
So I did jump those connectors after removing the relay. The pump comes on. As soon as I plug, i hear a whirring noise from the engine (which I thought it was weird because the pump is on the front, right?). However, putting my head near the battery, I can clear hear it on.
The car did not turn on, though. I don't have any equipment to check the fuel pressure yet, but the pump seems to be fine. This is what looks like:
http://youtu.be/kDAgZ362qls
I still have the P0102 - Mass air flow sensor short circuit/open circuit error after erasing the fault a couples times. Could be it?
Fuel pump is in the front, easy to hear in the front no question about that, I'm deaf as a post and can hear that when jumping the relay. Not sure why you'd hear anything from the back. You sure you're jumping the correct relay?
2003 S manual
