Old 07-03-2015, 02:16 PM   #22
Montesinnos
Montesinnos's Avatar
Have you checked fuel pressure?
Originally Posted by Jamesp View Post
I agree with Pwave on fuel pressure. You can force the pump to run by jumping the relay. if the pump runs with proper pressure, then check the crank position sensor. You can also put the old switch back in.
Hmmm, I will check. I think the durametric has an activation that lets you run the pump. Would that work?
Montesinnos is offline   Reply With Quote
