are you still on the original coolant cap or did you upgrade to the 2004?
A really old cap will hold less pressure each time you unscrew it. Should not go below 18 PSIG.
Replace every couple of years to be on the safe side.
Burping will cause you to pull your hair out.
Our resident mechanics have suggested using UV coolant dye to see if you have a weak link somewhere.
BORN: March 2000 - FINLAND
