Old 06-27-2015, 09:50 PM   #4
rick3000
There Is No Substitute.
rick3000's Avatar
I believe the second from the bottom opening is the same size as the two upper openings (where you have your double DIN install). You should be able to use the same trim for the AC as you would for the two upper openings (AC trim PN: 986 552 153 00 (satin black, they also make it in leather)). I believe only the lowest opening is a different size than the other three.
Can someone who has done this confirm?
The shelf for the lowest opening is PN: 996 552 243 01 (satin black)
