Thread: Hard starting
Old 06-25-2015, 05:15 PM   #2
luckyed7711
It means that the CPS is functioning correctly under the existing conditions. Problem with a CPS is that you need to check these tests when the car does not want to start, like after a heat soak. If the tests check out then, it is probably not the CPS.
I see. Yes. Thank you for the clarification.
luckyed7711 is offline   Reply With Quote
