Old 06-19-2015, 07:55 AM   #1
Qmulus
inveniam viam aut faciam
Originally Posted by martsink View Post
That's what I figured. I have the PDF wiring diagrams, but if you are kind, maybe you could point me in the right direction. I bought my car as a shell for a V8 swap, so what you see is how it came. The guy before me was also trying to build a V8 track car, so he cut a whole bunch of wires. Are the connectors specific to a function, or is it all random? Did you find any strategies to figuring out what each wire does, or was it just a laborious method of tracking each wire through countless diagrams? I would really appreciate some any input.
Thanks!
Vlad
Vlad,
Yes, you need to go pin by pin, I have never found a short cut. They are not random. What I would do is make a spreadsheet with the connectors, pin number, wire color and function (I also put to/from and signal information). You can then go through the wiring diagrams and fill in the blanks. It really isn't that bad. You might spend an hour or two on it, and then you will have it forever. The hardest part is resigning yourself to do it...
Steve
Qmulus is offline   Reply With Quote
