Old 06-19-2015, 03:33 AM   #11
rfuerst911sc
I'm no expert on flywheels so hopefully Jake will chime in. But I'll take an educated guess. The flywheel I purchased has a replaceable surface. So if/when the surface wears down you don't replace the entire flywheel you just replace the wear surface. The bulk of the weight has to be the mass of the flywheel so I don't think balance will be off by just replacing the flywheel surface.
rfuerst911sc is online now   Reply With Quote
