Old 06-18-2015, 04:16 PM   #11
Lapister
Kram, TRK, I'm following your build and man, the 987 airbox seems next to impossible to install. Kram I copied your use of retaining the buckle snaps on small end of box but even with both left engine cover retainer bent up out of way I'm having problems. If I start pushing front end down and in the flange buckles tend to hit oil cooler. Did you have to fight this bloody thing to go in? Also did you guys retain all 3 mounting points for box? I'm thinking of just cutting the very front one and use 2. The intake manifold and fuel rail are both out of the way albeit limited by hard pipe that runs through it. I know you guys made it work so what am I missing here? Please advise as once it's in its downhill for me. Thanks do I need to lower the engine mounts now? Ugh.
Lapister is offline   Reply With Quote
