Originally Posted by oc-boxster
I've decided against installing the wheel. My car is equipped with PSM, which my mechanic tells me will no longer work once the airbag is removed.
Plus, it's just silly to remove the airbag...turns out those things can actually save your life...
Mantis 2.0L Deep Sump, de-snorkeled, Bilstein PSS9 Coil-Overs, Rennline lug studs, and auto crossed regularly.
