Originally Posted by oc-boxster
I live in California we don't have any type of inspection, just smog. If the airbag light causes any problems with a smog check I guess I could just change it back before the test, I just want to make sure I can get the light turned off
You can't, unless you have a PWIS or Durametric. You can trick the ECU with a resistor arrangement, google it.
