Thread: Engine coolant
Old 06-13-2015, 03:01 PM   #4
newBgeek
Originally Posted by Hummer-addict View Post
Make sire you buy a OEM tank and use a new cap ending in 04...I got to do the job twice cause my aftermarket tank pushed antifreeze out of the overflow. I removed the engine cover the second time to reach the clamps...way easier then reaching from bottom with clamp tool.
I tried it both ways and found it way easier from the bottom because you can clearly see what you are doing as my photo shows. The guy from 101 projects made it seem like it was impossible to even look at the hoses without removing the transmission. Not true. You can easily view and reach the hoses at the same time, at least on my Boxster S.
newBgeek is offline   Reply With Quote
