Old 06-11-2015, 06:25 AM   #15
mikesz
mikesz's Avatar
get a piece of air tubing like for an airline for an aquarium with a diameter that will fit over the bleeder valve. get a small clean jar with a cap. punch a hole in the cap so the airline fits into the hole and reaches the bottom of the jar. half fill the jar with fresh clean brake fluid. prop the jar so it stays upright and wont fall over you can use wire or a large rubber band. open the valve and leave it open. make sure the brake reservoir is full. now pump on your brake pedal. the air bubbles will be forced out and when the brake pedal is released it will suck in new fluid from the jar.
99 Porsche Boxster
