Old 06-10-2015, 06:55 AM   #1
hancock1701
Yes, use the correct adaptor for the vehicle (Motive makes a lot), and put the fluid in the Motive unit like you are supposed to do. It only takes about 5 min. to clean out the Motive unit after you use it, and you will save a lot more time than that by not having to run around the car.
I think Motive only has a universal adapter for Hondas, which is the one with the chain around the reservoir to clamp it down. People on Honda forums say that adapter is very flimsy and hard to set up for air tightness.
hancock1701 is offline   Reply With Quote
