Old 06-04-2015, 10:21 PM   #1
BYprodriver
BYprodriver's Avatar
They are low tension rings against a low friction cylinder wall, but yes vacuum leak could cause slight loss of ring seal. Leaner air/fuel ratio from eliminating "false air" getting into intake without flowing thru the mass air sensor, is probably biggest reason for the improvement.
