Old 05-23-2015, 06:19 PM   #10
BFeller
So, scenario. Key is turned but no crank. Doesn't the fuel pump instantly make 55lbs or 3.8 bar? I'm not getting any pressure at all.
Second, Bently described how to pull the fuel pump relay, and jump the two terminals that would kick the fuel pump on, but I can't make it run with key in or out or turned to run position.
Bought new battery just in case.
I don't recall how much pressure it would build. I was running off of data from Bentley or 101 Projects.
