Old 05-23-2015, 03:23 PM   #10
BFeller
Fuel pressure pump cuts off if the engine does start for safety reasons. Durametric or the RPM Gauge doesn't register until the engine is turning over 800 RPM - one or the other - I can't remember. The starter doesn't turn the engine fast enough to register. My CPS quit without a single hiccup. The car started - an hour later nothing.
My fuel rail would build pressure - if released - when the pump ran for the short burst it would build pressure. So for me that ruled out fuel delivery issues.
If I remember correctly - there was compression - so I semi ruled out timing.
No error codes showed up in the Durametric to indicate any other issues.
So I tossed in a Pelican CPS. She started fine after it was installed.
