Old 05-17-2015, 08:31 PM   #2
Timco
I am my own mechanic....
Timco's Avatar
Thanks Tim, not the heat shields...had all that stuff off when I removed the rear axles for my bearing job. The couplers were in good condition, I reinstalled them using brand new stainless bolts....I have not tried removing the belt and running....you thinking water pump or ???
I had terrible start up noise. Turned out to be: 1) grooves in cam pulley had mostly filled with rubber. Made squishy sound or squawk sound 2) alternator bearing bad and made crunchy / rattle sound 3) water pump vanes rubbing on block opening until car warmed up. All startup noises, but alternator got worse.
Made a symphony of noises it turned out, but the work truck is a Ford so I was used to that. When those three things were fixed it was silent.
'08 VW Touareg T-3 wife's car
