Old 05-16-2015, 08:09 PM   #3
Guvs
Guvs's Avatar
But all it does is digs into the outer cable and stops dead because of the angle of the wire when pulled.
What I did was attach a length of electrical cable, (this was just to see if it worked will replace it with the correct wire later) to the bulk of the white plastic mechanism so I could pull it from that end and not try and slide the metal piece up, hope this makes sense, if you have a 987 have a look behind the boot lining you’ll see what I mean.
Sorry I had to do it in 3 threads as there were was too much detail for one hit.
Guvs.
Guvs is offline   Reply With Quote
