Thread: Horn Blows fuse
Old 05-13-2015, 12:59 PM   #1
rburro2
Rburro2
rburro2's Avatar
Originally Posted by SeanZ4 View Post
This is a common problem. Do a search on horn issues. It could be in the horn bracket up front, under the car. If I recall, the rubber gasket between the horn and the bracket can become worn and cause the horn to short out, and /or go off continuously. That would explain the previous owner removing the fuse. Good luck!
Thank you I will check that out.
2000 Boxster 2.7- First Porsche Owned
rburro2 is offline   Reply With Quote
