disconnect and re plug in the plug at the back of the ignition. Another thing you can do is un plug the connector and plug it into the new switch, place the key in the ignition so the immobilizer sees and reads the key in the key lock and use a screw driver to turn the electrical portion of the key switch. it should start. If it starts you know it is not the rest of the system but in the connection or the old switch.
