Old 05-06-2015, 11:14 AM   #7
BFeller
I understand the risk is low coolant introducing an air bubble that then creates a hot spot in the head that can result in cracking.
Are you sure the Airview system is sealing well at the tank neck? I had a small learning curve to getting the guage sealed at the neck. If so - put it under pressure and then check for leaks.
