Old 05-05-2015, 08:03 PM   #4
thstone
First, check to make sure that the tank is the cause - could easily be something else.
Whatever the cause, it should be repaired as soon as you can. In the meantime, check coolant level religiously and watch that temp gauge!
If the coolant light starts to slowly blink (even if the temp is ok), it means that the coolant level is low and needs to be topped up before bad things happen.
