Old 04-29-2015, 02:17 PM   #11
jaykay
jaykay's Avatar
Originally Posted by Ben006 View Post
The material will resist to oil and fuel
I don't know yet wich intake pipe will fit.
I tought the 3.2 used the same 68mm TB as the 2.7 ?
The nuts are hold in place in four hexagonal holes in the back of the mouting part.
Ben
Yes you are correct. I am just hoping for/to: use the stock 3.2 intake pipe with and adapter on the end along with a 74mm TB; outlets matching the intake plenum dia.; an AOS port that matches the stock location, so that a stock AOS hose can snap right in.
your angle looks pretty close to stock so the stock pipe looks promising....trust me when I say that this will be a big plus.
You could just 3D scan the stock pieces and then bring them into your software, modify to suit a 74mm TB...optimizing bend radii where possible....hmmm sounds like a business op
986 00S
