Old 04-26-2015, 09:26 PM   #1
antny
Yes you do. Axle's, control arm an pretty much everything on the rear suspension. Make sure you tighten the axle bolts correctly with some locktite. My axle bolts came out and pretty much destroyed my subframe and O2 sensor. Was not a fun experience. If you do not drop everything on the strut there is not enough room for he strut to clear the fender to remove. Once you do it once and just remove everything and not try to cut corners it will come out fine.
antny is offline   Reply With Quote
