Thread: Lack of power
Old 04-24-2015, 07:33 AM   #11
liquidimports84
You need a simple code reader.
You then do not have to disconnect battery to reset.
At this point you don't know what the code was so you can't target your repair.
Hunting idle can be due to dirty Throttle body/Intake (My issue - didn't throw code nor was power down)
I have also read that disconnecting the MAF is a diagnostic test. You should be able to hear it in the idle if it is hunting
just regular ODB2? I guess I will drive around with a hope that the engine light will come back
liquidimports84 is offline   Reply With Quote
