Old 04-23-2015, 11:23 AM   #11
F18febe
Originally Posted by nimblemotorsports View Post
I have them, I did not see a way to remove them from the carpet, is that possible?
Once you have removed the storage box (or for those who don't have a storage box) remove the carpet by turning the two fasteners (four for those without storage box) counterclockwise and lifting up (see picture). Once they are loose you should be able to pull the carpet from the car. The carpet piece is a bit heavy as it also includes sound deadening material. You should now be able to see the top of the engine cover (see picture).
This is what I found out ^^^^^^^^
I have the storage box with speakers and so I am only supposed to have two. So, I guess I don't need them. Thanks for checking anyway.
'04 Boxster S - Basalt Black, Fabspeed exhaust and sport headers, UD pulley, Pedro's Bluetooth, 18" Cayman S wheels, Evo cold air intake, IPD plenum, 74mm TB, Ben's SSK with ICT shifter boot, Fabspeed ECU Tune.
F18febe is offline   Reply With Quote
