Old 04-22-2015, 09:13 AM   #2
paulofto
2003 S, Arctic Silver, M6
paulofto's Avatar
Originally Posted by boxster6354 View Post
Just pull headlight out and make sure the plug is seated properly and place back in. I hit a pothole before and had same issue.
Agreed, I had a similar thing happen to me. I have Litronics and for some reason the high beams and fog lights went out but the low beam was okay. Turns out on Litronics the hi and fog have a separate connector to the light housing and it had worked loose some how. The main connection was fine.
Pull the entire housing and check the connections.
